I want the best suitable model in yolo with OBB for convert into hailo8 and hailo8l suggest me the best obb model in yolo
Hi @pavan_kumar, welcome to the Hailo Community! ![]()
I’d recommend starting with YOLO11n-OBB. It’s a lightweight model and a good starting point in terms of performance and accuracy.
We already have an Oriented Object Detection example in Hailo-Apps that supports YOLO11-OBB. The pre-trained network is available for download there already pre-compiled. You can also use Ultralytics’ direct Hailo export to convert YOLO11-OBB models to HEF. YOLO26-OBB is not currently supported by this export flow.
If you need higher accuracy, you could also consider YOLO11s-OBB, depending on your performance requirements.
