Which OS model to install in Raspberry pi 5 to use AI HAT+ 26 tops
i am using raspberry pi 5, along with raspberry pi AI HAT+ 26 TOPS, which OS version to install i raspberry pi 5 to use , because i have installed 64 bit- debian trixie, debian legacy bookworm, still unable to access the AI HAT+
Both Raspberry Pi OS 64-bit Debian Trixie and Debian Bookworm support the AI HAT+. The HailoRT version is different but the installation procedure is the same. Just follow the instruction using the official documentation.
Raspberry Pi - Documentation - AI HAT+
I would recommend using Debian Trixie so you can use the latest version of HailoRT and the Hailo AI Software Suite if you want to convert your own models.
