When is the new version release?
hello.
i think Hailo’ll be busy after the merger with microchip.
**when are the new updates for hailo8 and hailo10 scheduled?
And is the method of using multiple hailo10 chips in parallel for a single model under consideration?**
Hi @Yu_Eunsang,
Hailo-10H follows a quarterly release schedule, and v5.5.0 should be available on our DevZone within the next few days :slight_smile:
For Hailo-8/8L, releases are less frequent and are mainly driven by important bug fixes and new features.
It’s already possible to split a single vision model’s execution across multiple Hailo-10H devices. For GenAI nets, this is currently not supported.
@Marina_Vilela_Bento
Oh, really?
Until now, I thought it was impossible, and even our country’s Hailo branch office said it was not.
Hailo10 has built-in memory, so if i attach multiple Hailo10 NPUs to a device in parallel, can it process large language models while sharing memory?
Do you have any simple instructions or examples?
Many clients are waiting to see if this is available and how it works.
  • If that’s possible, for example, could multiple Hailo10h M.2 modules run a Qwen3 10B model?
  • Would that increase the number of tokens per second?
  • customers want a model with at least 7B, but only smaller models are available now, so it will be important whether it can use multiple chips as a single unit like the Hailo 8.
@Yu_Eunsang fixing my statement, as it is only possible for vision nets, my bad
Okay, Do you think it will be supported in hailo10’s LLM model as well?
@Marina_Vilela_Bento Do you know if v5.5.0 will support RTX 50-series GPUs for model optimization in the Dataflow Compiler? In the 2026-08 suite (DFC 5.4.0, TensorFlow 2.19.1 built against CUDA 12.5.1), TensorFlow detects my RTX 5070 Ti but fails with CUDA_ERROR_INVALID_PTX, so I have to run optimization on the CPU.
Hey, the version 5.5.0 still isn’t uploaded to the developer zone - is there a delay?
