Is it possible for multiple applications to use the Hailo-8L module independently, or does access to the Hailo device need to be managed within a single application?
For example, I may have a Raspberry Pi connected to two different camera sources, with each camera being processed by a different application. Alternatively, it could be the same application running two separate instances.
What would be the recommended approach for this?
I am planning to use multiple IP cameras, all requiring AI detection. However, each camera may be detecting different objects or events, so I am currently considering how best to structure the overall system architecture and manage access to the Hailo accelerator.
Thank you.
