Run each hef file by each device-id
is it possible to set the hailo8 chip directly for each device-id
and run each hef file in parrallel?
or is it only possible to automatically be assigned to idel chips?
Yes, you can specify the device-id when you run a network. For example when you use the HailoRT CLI
hailortcli run model.hef --device-id 0000:nn:00.0
You can get the device-id by running the scan command.
hailortcli scan
You can use the HailoRT monitor to see on which device the model runs.
In one terminal run
hailortcli monitor
In a second terminal first set the HAILO_MONITOR variable to 1 and then run you app or CLI command.
export HAILO_MONITOR=1
