Yeah it would start the server in one window then in my other I was getting this:
pi@Pi5:~ $ curl -X POST http://localhost:8000/api/pull -H “Content-Type: application/json” -d ‘{“name”: “llama3.2:3b”}’
Hello Michael. Thanks for your comprehensive reply. I followed your instructions fully, and am able to say that the installation of hailo-apps appeared to complete successfully at some levels, although the reources all seem to be missing.
Here is a sample of what was logged. I haven’t included all of them, but you will see what the problem is: “downloaded file size does not match expected size”.
When I perform hailo-detect, I get the following error:
ERROR | installation.download_resources | Failed to download after 3 attempts: Downloaded file size (19905761) doesn’t match expected size (25501728)
WARNING | installation.download_resources | Some downloads failed:
WARNING | installation.download_resources | - yolov8m: Failed to download after 3 attempts: Downloaded file size (19905761) doesn’t match expected size (25501728)
ERROR | common.core | Download succeeded but file not found: /usr/local/hailo/resources/models/hailo10h/yolov8m.hef
In addition, whereas before I was able to access the ai both on the command line and via Open WebUI by issuing the command hailo-ollama, that command is no longer recognised.
OK, I decided to risk it and reinstalled the hailo-ollama server, and that at least seems to be working as it should. So please ignore the last paragraph above.
The connection has been fine. If it was occasional drop-outs, then at least some of the resources would have succeeded. Also, the rest of the draw-down all seems to have worked. It looks as if all of the download_resources files failed, though, and they all say that the file size is the problem.
I have set up the virtual environment source setup_env.sh. I have then done hailo-download-resources --all. The resources seem to download correctly, with the exception of the hef files. Not a single one of these downloads! One sample line from the log:
What is going wrong here? It isn’t a connection issue. I have checked the folder ~/hailo-apps/resources and all the sub-folders are populated except for /packages/ which is empty.
OK, I don’t have the fastest internet in the world. I’m waiting for my fibre-optic connection to arrive. In the meanwhile, my existing speeds are quite adequate for everything else I do. Why does this hailo-apps setup give such a short time for the download to occur? Is there a time-out set in the install.sh set-up?
Downloading resource: yolov8m_pose (type: model)
✓ URL valid: https://hailo-model-zoo.s3.eu-west-2.amazonaws.com/ModelZoo/Compiled/v5.1.0/hailo10h/yolov8m_pose.hef
Status: 200
[====================================----] 92% (25.77/28.01 MB)
WARNING | installation.download_resources | Download attempt 1/3 failed for https://hailo-model-zoo.s3.eu-west-2.amazonaws.com/ModelZoo/Compiled/v5.1.0/hailo10h/yolov8m_pose.hef: Downloaded file size (27050753) doesn't match expected size (29367944)
[=================================-------] 84% (23.53/28.01 MB)
WARNING | installation.download_resources | Download attempt 2/3 failed for https://hailo-model-zoo.s3.eu-west-2.amazonaws.com/ModelZoo/Compiled/v5.1.0/hailo10h/yolov8m_pose.hef: Downloaded file size (24871529) doesn't match expected size (29367944)
WARNING | installation.download_resources | Download attempt 3/3 failed for https://hailo-model-zoo.s3.eu-west-2.amazonaws.com/ModelZoo/Compiled/v5.1.0/hailo10h/yolov8m_pose.hef: Downloaded file size (24922317) doesn't match expected size (29367944)
ERROR | installation.download_resources | Failed to download after 3 attempts: Downloaded file size (24922317) doesn't match expected size (29367944)
WARNING | installation.download_resources | - yolov8m_pose: Failed to download after 3 attempts: Downloaded file size (24922317) doesn't match expected size (29367944)
ERROR | common.core | Download succeeded but file not found: /usr/local/hailo/resources/models/hailo10h/yolov8m_pose.hef
This is driving me mad! Surely there must be a way of downloading these files from another source which is more tolerant of relatively slow download speeds? After all, mine seems to get 84%+ downloaded before it gives up.
