Possible framerate bug
I’ve been using the tiling app which is amazing by the way. I noticed the Hailo-10H was getting quite hot so I thought I’d try using --frame-rate to lighten the load, as I don’t need a high framerate for my application. However it doesn’t seem to have any effect when using --input rpi.
Looking at the code, picamera_thread() in gstreamer_app.py appears to hardcode FrameRate: 30 when configuring picamera2, so --frame-rate is silently ignored for the RPi camera source.
Running hailo-apps v26.03.1 on a Raspberry Pi 5 with Hailo-10H.
Thanks @sjnicholls414 for raising the issue - we will fix ASAP.
