No successful assignments: concat23 errors: Agent infeasible
Hello! I trained a model on yolov11m, with imgsz 640x640 , using DFC i executed all required commands, parser, optimize, but when i try to compile it, it returns this error:
hailo compiler --hw-arch hailo8 model_best_optimized.har
E0000 00:00:1770812332.942657 1761958 cuda_dnn.cc:8310] Unable to register cuDNN factory: Attempting to register factory for plugin cuDNN when one has already been registered
E0000 00:00:1770812332.949248 1761958 cuda_blas.cc:1418] Unable to register cuBLAS factory: Attempting to register factory for plugin cuBLAS when one has already been registered
[info] Current Time: 12:18:59, 02/11/26
[info] CPU: Architecture: x86_64, Model: Intel(R) Xeon(R) Silver 4314 CPU @ 2.40GHz, Number Of Cores: 16, Utilization: 0.1%
[info] Memory: Total: 31GB, Available: 30GB
[info] System info: OS: Linux, Kernel: 5.15.0-70-generic
[info] Hailo DFC Version: 3.32.0
[info] Running `hailo compiler --hw-arch hailo8 model_best_optimized.har`
[info] Compiling network
[info] Building optimization options for network layers…
[info] Successfully built optimization options - 2m 54s 915ms
[info] Successfully built optimization options - 3m 16s 553ms
[error] Mapping Failed (allocation time: 3m 16s)
Agent infeasible
[error] BackendAllocatorException: Compilation failed: No successful assignments: concat23 errors:
Agent infeasible
After looking a bit online i tried again but this time exporting to onnx with imgsz 416x416 images kind of worked
Can someone help me understand why it throws those errors? Thanks
