Hello, I am reporting an error when converting onnx to hef. Could you please help me take a look. The relevant code is as follows:
Convert onnx code:
import argparse
import os
import sys
import torch
import torch.nn as nn
# add project root to import path
ROOT = os.path.abspath(os.path.join(os.path.dirname(__file__), "..", "..", ".."))
if ROOT not in sys.path:
sys.path.insert(0, ROOT)
from projects.mmdet3d_plugin.models.detection3d.detection3d_blocks import SparseBox3DEncoder
class LastDimBatchNorm(nn.BatchNorm1d):
def forward(self, x):
shape = x.shape
x = super().forward(x.reshape(-1, shape[-1]))
return x.view(shape)
class LayerNormViaLinear(nn.Module):
def __init__(self, normalized_shape, eps=1e-5, elementwise_affine=True):
super().__init__()
C = int(normalized_shape[0]) if isinstance(normalized_shape, (list, tuple)) else int(normalized_shape)
self.eps = eps
self.elementwise_affine = elementwise_affine
self.w_sum = nn.Parameter(torch.ones(C, 1), requires_grad=False)
self.w_sumsq = nn.Parameter(torch.ones(C, 1), requires_grad=False)
self.register_buffer("invC", torch.tensor(1.0 / C))
if elementwise_affine:
self.weight = nn.Parameter(torch.ones(C))
self.bias = nn.Parameter(torch.zeros(C))
else:
self.register_parameter("weight", None)
self.register_parameter("bias", None)
mean = torch.matmul(x, self.w_sum) * self.invC
var = torch.matmul(x * x, self.w_sumsq) * self.invC - mean * mean
x_hat = (x - mean) * torch.rsqrt(var + self.eps)
if self.elementwise_affine:
x_hat = x_hat * self.weight + self.bias
return x_hat
def collect_layernorm_stats(model: nn.Module, data_list):
stats = {}
handles = []
def hook(mod, inp, out):
x = inp[0]
mean = x.mean(dim=(0, 1))
var = x.var(dim=(0, 1), unbiased=False)
if mod not in stats:
stats[mod] = {"mean": mean.detach(), "var": var.detach(), "count": 1}
else:
stats[mod]["mean"] += mean.detach()
stats[mod]["var"] += var.detach()
stats[mod]["count"] += 1
for m in model.modules():
if isinstance(m, nn.LayerNorm):
handles.append(m.register_forward_hook(hook))
model.eval()
with torch.no_grad():
for data in data_list:
model(data)
for h in handles:
h.remove()
avg_stats = {}
for mod, v in stats.items():
c = v["count"]
avg_stats[mod] = (v["mean"] / c, v["var"] / c)
return avg_stats
def patch_norm(module: nn.Module, mode: str, stats: dict = None):
for name, child in list(module.named_children()):
if isinstance(child, nn.LayerNorm):
if mode == "batchnorm":
bn = LastDimBatchNorm(
child.normalized_shape[-1], affine=True, track_running_stats=True, momentum=0.0
if child.elementwise_affine:
bn.weight.copy_(child.weight)
bn.bias.copy_(child.bias)
bn.eps = child.eps
if stats is not None and child in stats:
mean, var = stats[child]
bn.running_mean.copy_(mean)
bn.running_var.copy_(var)
else:
bn.running_mean.zero_()
bn.running_var.fill_(1.0)
setattr(module, name, bn)
elif mode == "linearln":
ln = LayerNormViaLinear(
child.normalized_shape, eps=child.eps, elementwise_affine=child.elementwise_affine
ln.weight.copy_(child.weight)
ln.bias.copy_(child.bias)
setattr(module, name, ln)
elif mode == "none":
setattr(module, name, nn.Identity())
else:
patch_norm(child, mode, stats)
def load_checkpoint_into_module(module: torch.nn.Module, ckpt_path: str):
ckpt = torch.load(ckpt_path, map_location="cpu")
state = ckpt["state_dict"] if isinstance(ckpt, dict) and "state_dict" in ckpt else ckpt
prefix_candidates = ["head.anchor_encoder.", "module.head.anchor_encoder.", "anchor_encoder."]
new_state = {}
for k, v in state.items():
for pre in prefix_candidates:
if k.startswith(pre):
new_state[k[len(pre) :]] = v
break
missing, unexpected = module.load_state_dict(new_state, strict=False)
print(f"Loaded checkpoint: {ckpt_path}")
if missing:
print("Missing keys in encoder:", missing)
if unexpected:
print("Unexpected keys ignored:", unexpected)
class EncoderExportWrapper(torch.nn.Module):
def __init__(self, encoder: torch.nn.Module):
super().__init__()
self.encoder = encoder
def forward(self, anchor):
# pos, size, yaw, vel = torch.split(anchor, [3, 3, 2, self.encoder.vel_dims], dim=-1)
vel_start_idx = 8
# 使用切片操作 [..., start:end]
pos = anchor[..., 0:3]
size = anchor[..., 3:6]
yaw = anchor[..., 6:vel_start_idx]
vel = anchor[..., vel_start_idx:]
pos_feat = self.encoder.pos_fc(pos)
size_feat = self.encoder.size_fc(size)
yaw_feat = self.encoder.yaw_fc(yaw)
# **** 修改区域 ****
# 移除了 4D Reshape (pos_feat.reshape(...) 等)
# **** 结束修改区域 ****
if self.encoder.mode == "add":
# 在 dim=-1 (特征维度) 上进行逐元素相加
output = pos_feat + size_feat + yaw_feat
else:
# 模式为 "cat",在 dim=-1 (特征维度) 上进行拼接
output = torch.cat([pos_feat, size_feat, yaw_feat], dim=-1)
if self.encoder.vel_dims > 0:
vel_feat = self.encoder.vel_fc(vel)
# 移除了 vel_feat 的 4D Reshape
output = output + vel_feat if self.encoder.mode == "add" else torch.cat([output, vel_feat], dim=-1)
if self.encoder.output_fc is not None:
output = self.encoder.output_fc(output)
# 移除了最后的 reshape,直接返回 (B, N, C_total) 形状
return output
class EncoderMultiInputWrapper(torch.nn.Module):
super().__init__()
def forward(self, pos, size, yaw, vel=None):
# **** 修改区域 ****
# 移除了 4D Reshape
# **** 结束修改区域 ****
else:
if vel is not None and self.encoder.vel_dims > 0:
# 移除了最后的 reshape
return output
def parse_args():
p = argparse.ArgumentParser()
p.add_argument("--ckpt", default=“”)
p.add_argument("--out", default="")
p.add_argument("--bs", type=int, default=6)
p.add_argument("--num_anchor", type=int, default=900)
p.add_argument("--state_dim", type=int, default=11)
p.add_argument("--opset", type=int, default=13)
p.add_argument("--no_decouple", action="store_true")
p.add_argument("--norm", choices=["layernorm", "batchnorm", "none", "linearln"], default="layernorm")
p.add_argument("--calib_batches", type=int, default=0)
p.add_argument("--no_simplify", action="store_true")
p.add_argument("--multi_input", action="store_true", help="Export 4 inputs (pos/size/yaw/vel)")
return p.parse_args()
def main():
args = parse_args()
decouple_attn = not args.no_decouple
os.makedirs(os.path.dirname(args.out), exist_ok=True)
print(f"Configuring Encoder with decouple_attn={decouple_attn}...")
if decouple_attn:
embed_dims_arg, mode_arg, output_fc_arg, out_loops_arg = [128, 32, 32, 64], "cat", False, 4
else:
embed_dims_arg, mode_arg, output_fc_arg, out_loops_arg = 256, "add", True, 2
encoder = SparseBox3DEncoder(
vel_dims=3,
embed_dims=embed_dims_arg,
mode=mode_arg,
output_fc=output_fc_arg,
in_loops=1,
out_loops=out_loops_arg,
if os.path.exists(args.ckpt):
load_checkpoint_into_module(encoder, args.ckpt)
else:
print("Error: checkpoint not found at", args.ckpt)
return
if args.norm != "layernorm":
stats = None
if args.norm == "batchnorm" and args.calib_batches > 0:
calib_data = [
torch.randn(args.bs, args.num_anchor, args.state_dim, dtype=torch.float32)
for _ in range(args.calib_batches)
stats = collect_layernorm_stats(encoder, calib_data)
print(f"Applying norm override: {args.norm}")
patch_norm(encoder, args.norm, stats)
wrapper = EncoderMultiInputWrapper(encoder) if args.multi_input else EncoderExportWrapper(encoder)
wrapper = wrapper.eval()
dummy_anchor = torch.randn(args.bs, args.num_anchor, args.state_dim, dtype=torch.float32)
dummy_pos = dummy_anchor[..., :3]
dummy_size = dummy_anchor[..., 3:6]
dummy_yaw = dummy_anchor[..., 6:8]
dummy_vel = dummy_anchor[..., 8 : 8 + 3] if encoder.vel_dims > 0 else None
export_path = os.path.abspath(args.out)
print(f"Exporting encoder to ONNX -> {export_path}")
if args.multi_input:
inputs = (dummy_pos, dummy_size, dummy_yaw, dummy_vel)
input_names = ["pos", "size", "yaw", "vel"]
else:
inputs = (dummy_anchor,)
input_names = ["anchor"]
torch.onnx.export(
wrapper,
inputs,
export_path,
opset_version=args.opset,
do_constant_folding=True,
input_names=input_names,
output_names=["anchor_embed"],
dynamic_axes=None,
verbose=True,
print("ONNX export finished.")
if not args.no_simplify:
try:
import onnx
from onnxsim import simplify
print("Trying to simplify ONNX model with onnx-simplifier...")
model = onnx.load(export_path)
model_simp, check = simplify(model)
if check:
onnx.save(model_simp, export_path)
print("Simplified and overwritten ONNX model.")
else:
print("onnx-simplifier check failed; keeping original export.")
except ImportError:
print("onnx-simplifier module not found. Skipping simplification.")
except Exception as e:
print("onnx-simplifier failed:", e)
else:
print("Skipped onnx-simplifier as requested.")
print("Done.")
if __name__ == "__main__":
main()
onnx to hef:
import os
import sys
import logging
import onnx
import onnx.checker
logging.basicConfig(level=logging.INFO, format="%(asctime)s - %(levelname)s - %(message)s")
log = logging.getLogger("onnx2hef_encoder")
# 配置
ONNX_PATH = "1.onnx"
# 改回单输入 anchor,避免多输入校准 KeyError
USE_MULTI_INPUT = False
B, NUM_ANCHOR, STATE_DIM = 6, 900, 11
OUTDIR = "onnx_models/hailo_outputs_encoder"
NET_NAME = "box3d_encoder"
HW_ARCH = "hailo8"
HAR_FLOAT = os.path.join(OUTDIR, f"{NET_NAME}_hailo_model.har")
HAR_QUANT = os.path.join(OUTDIR, f"{NET_NAME}_hailo_quantized_model.har")
HEF_PATH = os.path.join(OUTDIR, f"{NET_NAME}.hef")
CALIB_SAMPLES = 32
RNG_SEED = 42
def verify_onnx(path: str, input_names):
assert os.path.exists(path), f"ONNX 不存在: {path}"
m = onnx.load(path)
onnx.checker.check_model(m)
inputs = [i.name for i in m.graph.input]
log.info(f"ONNX 输入: {inputs}")
for name in input_names:
if name not in inputs:
log.warning(f"期望输入名 '{name}',实际 {inputs}。")
def main():
os.makedirs(OUTDIR, exist_ok=True)
net_input_shapes = {"anchor": (B, NUM_ANCHOR, STATE_DIM)}
verify_onnx(ONNX_PATH, input_names)
runner = ClientRunner(hw_arch=HW_ARCH)
runner.translate_onnx_model(
model=ONNX_PATH,
net_name=NET_NAME,
net_input_shapes=net_input_shapes,
start_node_names=input_names,
runner.save_har(HAR_FLOAT)
log.info(f"HAR(float) 已保存: {HAR_FLOAT}")
script_lines = [
"model_optimization_flavor(optimization_level=2, compression_level=0)",
"resources_param(max_control_utilization=0.6, max_compute_utilization=0.6, max_memory_utilization=0.6)",
try:
runner.load_model_script("\n".join(script_lines))
log.info("model script 已加载。")
log.warning(f"model script 加载失败,可忽略/按需调整: {e}")
np.random.seed(RNG_SEED)
if USE_MULTI_INPUT:
# Hailo optimize 对多输入更稳:tuple of numpy arrays, 第一维是校准样本数,顺序与 start_node_names 对齐
calib = {
"pos": np.random.randn(CALIB_SAMPLES, B, NUM_ANCHOR, STATE_SPLIT["pos"]).astype(np.float32),
"size": np.random.randn(CALIB_SAMPLES, B, NUM_ANCHOR, STATE_SPLIT["size"]).astype(np.float32),
"yaw": np.random.randn(CALIB_SAMPLES, B, NUM_ANCHOR, STATE_SPLIT["yaw"]).astype(np.float32),
"vel": np.random.randn(CALIB_SAMPLES, B, NUM_ANCHOR, STATE_SPLIT["vel"]).astype(np.float32),
log.info("校准数据: multi-input random anchors (dict of np_array)")
else:
calib = np.random.randn(CALIB_SAMPLES, B, NUM_ANCHOR, sum(STATE_SPLIT.values())).astype(np.float32)
log.info(f"校准数据: shape={calib.shape}, dtype={calib.dtype}")
# 明确传递校准数据类型
runner.optimize(calib, data_type="np_array")
log.info("Optimize 完成(生成量化权重)。")
try:
runner.save_har(HAR_QUANT)
log.info(f"HAR(quantized) 已保存: {HAR_QUANT}")
log.info(f"保存量化 HAR 失败(可能 SDK 不支持写回量化信息): {e}")
try:
hef = runner.compile()
try:
hef.save(HEF_PATH)
except Exception:
with open(HEF_PATH, "wb") as f:
f.write(hef)
log.info(f"HEF 已导出: {HEF_PATH}")
except AttributeError:
runner.save_hef(HEF_PATH)
log.info(f"HEF 已导出(save_hef): {HEF_PATH}")
log.info("完成 ONNX -> HAR -> Optimize(量化) -> HEF 全流程。")
main()
error:
[info] Simplified ONNX model for a parsing retry attempt (completion time: 00:00:00.51)
File "/home/ubuntu/.conda/envs/sparse4d_new/lib/python3.8/site-packages/hailo_sdk_client/sdk_backend/parser/parser.py", line 179, in translate_onnx_model
parsing_results = self._parse_onnx_model_to_hn(onnx_model, valid_net_name, start_node_names,
File "/home/ubuntu/.conda/envs/sparse4d_new/lib/python3.8/site-packages/hailo_sdk_client/sdk_backend/parser/parser.py", line 237, in _parse_onnx_model_to_hn
return self.parse_model_to_hn(onnx_model, None, net_name, start_node_names, end_node_names,
File "/home/ubuntu/.conda/envs/sparse4d_new/lib/python3.8/site-packages/hailo_sdk_client/sdk_backend/parser/parser.py", line 263, in parse_model_to_hn
File "/home/ubuntu/.conda/envs/sparse4d_new/lib/python3.8/site-packages/hailo_sdk_client/model_translator/translator.py", line 76, in convert_model
self._create_layers()
File "/home/ubuntu/.conda/envs/sparse4d_new/lib/python3.8/site-packages/hailo_sdk_client/model_translator/edge_nn_translator.py", line 28, in _create_layers
self._add_direct_layers()
File "/home/ubuntu/.conda/envs/sparse4d_new/lib/python3.8/site-packages/hailo_sdk_client/model_translator/edge_nn_translator.py", line 121, in _add_direct_layers
node.update_output_format(vertex)
File "/home/ubuntu/.conda/envs/sparse4d_new/lib/python3.8/site-packages/hailo_sdk_client/model_translator/onnx_translator/onnx_graph.py", line 220, in update_output_format
elif self.op == 'MatMul' and self.is_matmul_layer():
File "/home/ubuntu/.conda/envs/sparse4d_new/lib/python3.8/site-packages/hailo_sdk_client/model_translator/onnx_translator/onnx_graph.py", line 2948, in is_matmul_layer
kernel, _ = self.get_kernel()
File "/home/ubuntu/.conda/envs/sparse4d_new/lib/python3.8/site-packages/hailo_sdk_client/model_translator/onnx_translator/onnx_graph.py", line 443, in get_kernel
const_shape = pred._info.attribute[0].t.dims
IndexError: list index (0) out of range
File "projects/mmdet3d_plugin/tools/head/hailloe.py", line 105, in <module>
main()
File "projects/mmdet3d_plugin/tools/head/hailloe.py", line 47, in main
File "/home/ubuntu/.conda/envs/sparse4d_new/lib/python3.8/site-packages/hailo_sdk_common/states/states.py", line 16, in wrapped_func
File "/home/ubuntu/.conda/envs/sparse4d_new/lib/python3.8/site-packages/hailo_sdk_client/runner/client_runner.py", line 876, in translate_onnx_model
parser.translate_onnx_model(model=model, net_name=net_name, start_node_names=start_node_names,
File "/home/ubuntu/.conda/envs/sparse4d_new/lib/python3.8/site-packages/hailo_sdk_client/sdk_backend/parser/parser.py", line 211, in translate_onnx_model
parsing_results = self._parse_onnx_model_to_hn(simplified_model, valid_net_name,
File "/home/ubuntu/.conda/envs/sparse4d_new/lib/python3.8/site-packages/hailo_sdk_client/model_translator/translator.py", line 85, in convert_model
self._calculate_shapes(validate_shapes=False)
File "/home/ubuntu/.conda/envs/sparse4d_new/lib/python3.8/site-packages/hailo_sdk_client/model_translator/onnx_translator/onnx_translator.py", line 110, in _calculate_shapes
self._layers_graph.calculate_shapes(meta_edges_graph=self._meta_graph, validate_shapes=validate_shapes)
File "/home/ubuntu/.conda/envs/sparse4d_new/lib/python3.8/site-packages/hailo_sdk_common/hailo_nn/hailo_nn.py", line 627, in calculate_shapes
self.update_input_shapes_from_predecessors(layer)
File "/home/ubuntu/.conda/envs/sparse4d_new/lib/python3.8/site-packages/hailo_sdk_common/hailo_nn/hailo_nn.py", line 668, in update_input_shapes_from_predecessors
layer.input_shapes = input_shapes
File "/home/ubuntu/.conda/envs/sparse4d_new/lib/python3.8/site-packages/hailo_sdk_common/hailo_nn/hn_layers/layer.py", line 505, in input_shapes
self.set_input_shapes(input_shapes)
File "/home/ubuntu/.conda/envs/sparse4d_new/lib/python3.8/site-packages/hailo_sdk_common/hailo_nn/hn_layers/conv2d.py", line 511, in set_input_shapes
raise UnsupportedModelError(
hailo_sdk_common.hailo_nn.exceptions.UnsupportedModelError: Invalid kernel shape for base conv layer base_conv1 (translated from /pos_fc/pos_fc.0/Add).
Either the input shape doesn't match the kernel shape, or the calculated groups number doesn't match the expected ratio between kernel shape and input shape.
Kernel features: 3 Input features: 11 Groups: 3
