Hi there,
I’m using a setup with multiple rpi5 with camera modules, and a rpi5 with hailo 8l, all connected in a local network.
I’m using gstreamer to stream the video, a gst hailo pipeline to recieve the stream and run inference, and hailoexportzmq element to stream the metadata.
I have another rpi5 on the network connected to a display, which is receiving and recording the video stream (from the pi with camera), and also receiving and recording the metadata zmq stream (from the pi with hailo).
This setup might seem complicated but it satisfies my constraints.
My requirement:
I want to draw the bboxes on the frames once i recieve it on the pi with display and also perform basic frame by frame analysis based on the metadata.
My problem:
I"m having trouble associating the correct metadata with the correct frame. timestamps arent helpful as there are time/network delays in between. frame numbers arent helpful as there is a mismatch.
Can someone please help me come up with a solution?
If i know where the timestamp is added to the buffer metadata, maybe i can replace that timestamp with the timestamp of video frame creation which is already in the buffer, so that the timestamp stays constant and can easily be associated with the frame regardless of delays.
could you please suggest any edits to the cpp/hpp files to edit so i can recompile the so files if needed?
could you help me locate where the timestamp, buffer_offset, stream_id are created/added to the buffer so i can edit it?
Thank you, looking forward to your ideas!
