With my below infer method, my hailo log is filling up with
[2025-08-14 15:59:27.259] [2844] [HailoRT] [info] [hef.cpp:1994] [get_network_group_and_network_name] No name was given. Addressing all networks of default network_group: model
[2025-08-14 15:59:27.364] [2844] [HailoRT] [info] [hef.cpp:1994] [get_network_group_and_network_name] No name was given. Addressing all networks of default network_group: model
[2025-08-14 15:59:27.463] [2844] [HailoRT] [info] [hef.cpp:1994] [get_network_group_and_network_name] No name was given. Addressing all networks of default network_group: model
[2025-08-14 15:59:27.564] [2844] [HailoRT] [info] [hef.cpp:1994] [get_network_group_and_network_name] No name was given. Addressing all networks of default network_group: model
def infer(should_use_multi_process_service=False, model_path=None):
# Create a VDevice
params.group_id = "SHARED"
if should_use_multi_process_service:
params.multi_process_service = should_use_multi_process_service
hef = pyhailort.pyhailort.HEF(model_path)
network_group_names = hef.get_network_group_names()
# Create an infer model from an HEF:
infer_model = vdevice.create_infer_model(model_path, name=network_group_names[0])
# Set optional infer model parameters
infer_model.set_batch_size(1)
# For a single input / output model, the input / output object
# can be accessed with a name parameter ...
if "model.hef" in model_path:
infer_model.input("model/input_layer1").set_format_type(FormatType.UINT8)
infer_model.output().set_format_type(FormatType.FLOAT32)
else:
infer_model.input("vits_indoor_224_224/input_layer1").set_format_type(FormatType.UINT8)
infer_model.output().set_format_type(FormatType.UINT8)
# Once the infer model is set, configure the infer model
for _ in range(number_of_frames):
# Create bindings for it and set buffers
bindings.input().set_buffer(np.empty(infer_model.input().shape).astype(np.uint8))
bindings.output().set_buffer(np.empty(infer_model.output().shape).astype(np.float32 if "model.hef" in model_path else np.uint8))
# Wait for the async pipeline to be ready, and start an async inference job
configured_infer_model.wait_for_async_ready(timeout_ms=10000)
# Any callable can be passed as callback (lambda, function, functools.partial), as long
# as it has a keyword argument "completion_info"
job = configured_infer_model.run_async([bindings], partial(example_callback, bindings=bindings))
# Wait for the last job
job.wait(timeout_ms)
I found this forum post PythonAPI: hailort.log polluted by 'No name was given' every video-frame - #3 by omria
But this does not work with how I am currently doing the inference, and I can’t find any documentation on how to set the network group names using the VDevice object as i am now. Could someone give some guidance on this issue? The hailort logs are getting spammed with the message for every inference making it hard to debug. Thank you!
