Help needed :How to correctly connect and configure Hailo-8 M.2 key A +E key 2230 for Raspi 5
Hi Hailo Community,
I have recently purchased a Hailo-8 M.2 Key A+E 2230 module, and I am currently seeking advice on how to correctly integrate it with my Raspberry Pi 5.
Since I have already purchased this specific module, I would like to find the most viable and stable way to set it up. I have a few technical questions regarding the hardware requirements and installation:
1. Compatibility: Is the Hailo-8 M.2 Key A+E 2230 module compatible with the Raspberry Pi 5?
2. Connection/Hardware: What is the recommended assembly method for this module? Does it require a specific PCIe expansion board or HAT, or is it possible to use a third-party PCIe adapter (e.g., an E-Key to M-Key adapter)?
3. Best Practices: If you have any recommendations for specific adapter boards or the correct physical configuration to interface an A+E Key module with the Pi 5’s PCIe port, please let me know.
4. Software/Drivers: Are there any specific drivers or configuration steps I should be aware of when using this A+E Key version on Raspberry Pi OS?
I want to ensure I follow the correct path to avoid compatibility issues or purchasing unnecessary hardware. Any documentation, assembly advice, or links to relevant guides would be greatly appreciated.
Thank you very much for your time and assistance.
Please have a look at the following post:
Hailo Community - How to connect a Hailo-8 to the Raspberry Pi 5
I tested a HAT with an M.2 A+E key slot from Pineboards. Maybe its still available, the company may have gone out of business.
There may be other HATs available with A+E key support. However M.2 key M HATs are more widely available because key M is used for SSDs.
The software and drivers will stay the same. No additional configuration steps are necessary.
Thank you for your helpful reply and for sharing the guide.
To clarify, I am looking for an M.2 E-key or A + E key to M-key adapter board, similar to the one shown in the attached image. Specifically, I mean a board with an E-key socket for my Hailo-8 M.2 A+E-key module, and an M-key edge connector that plugs into an M.2 M-key HAT for the Raspberry Pi 5.
As you mentioned, most HATs available in my region have M-key slots because they are designed for SSDs. HATs with E-key slots are much harder to find, so I am hoping to use a suitable adapter board with an M-key HAT.
Before purchasing one, I would like to confirm that it provides the PCIe signal routing and power required by the Hailo-8 module. My concern is that a board may physically fit but may not be electrically compatible, especially if it is designed only for a particular type of device.
Do you know of any specific E-key-to-M-key adapter boards that would work with the Hailo-8 A+E-key module on the Raspberry Pi 5? If so, I would greatly appreciate any model names or product links you could share. Recommendations for compatible HAT-and-adapter-board combinations would also be very helpful, particularly if you have tested them yourself.
Thank you very much for your time and assistance. Have a wonderful day!
Unfortunately, not. Most of these adapters are no-name products, but we didn’t encounter any issues with adapters without PCIe switches during our short tests.
For a more robust setup, I would avoid using multiple adapters. Instead, I recommend either looking for a HAT that supports an M.2 Key A+E module or using a Hailo-8 M.2 Key M module.
