Hey all,
I’ve got my PI up and running with AI HAT+ using the following guide: https://www.raspberrypi.com/documentation/computers/ai.html
I then went to install the examples from GitHub - hailo-ai/hailo-rpi5-examples
Using the setup_env script, everything goes smoothly until compiling. Then errors start:
../cpp/yolov8pose_postprocess.cpp:326:109: error: ‘using std::__shared_ptr_access<HailoTensor, __gnu_cxx::_S_atomic, false, false>::element_type = class HailoTensor’ {aka ‘class HailoTensor’} has no member named ‘vstream_info’
326 | auto dequantized_output_s = common::dequantize(common::get_xtensor(tensors[i + 1]), tensors[i + 1]->vstream_info().quant_info.qp_scale, tensors[i + 1]->vstream_info().quant_info.qp_zp);
../cpp/yolov8pose_postprocess.cpp:326:161: error: ‘using std::__shared_ptr_access<HailoTensor, __gnu_cxx::_S_atomic, false, false>::element_type = class HailoTensor’ {aka ‘class HailoTensor’} has no member named ‘vstream_info’
ninja: build stopped: subcommand failed.
ERROR:hailo_apps.hailo_app_python.core.installation.compile_cpp:C++ postprocess build failed (exit 1)
Doing a little research I understand:
The issue is an API change in HailoRT 4.23.0. The vstream_info() method has been removed or changed. In newer versions of HailoRT, you typically need to access quantization parameters differently.
I tried going back to the previous tag in git but it required downgrading hailo tappas core to 3.30. That failed as it’s referred to by another package.
Any idea what might be wrong and how to fix? I’d prefer to run the latest examples!
Thanks
