Hailo 8, seems to be fine, but any of the basic examples doesn't work
Hi @Juan_Hidalgo,
Could you check what kernel version you’re running on your Raspberry Pi? Just run this command:
uname -r
If you’re on anything higher than 6.12.20, you’ll need to downgrade it. There’s a compatibility issue with newer kernels. I’ve put together a guide with the steps you’ll need to follow here: Raspberry Pi Kernel Compatibility Issue - Temporary Fix
Let me know if you run into any issues with the downgrade process!
