The result of the conversion is as shown below, an error has occurred.
Q1. Is an onnx vgg16_Opset18.onnx converted to HAR successfully?
Q2. Are there any failed processes in converting the HAR to vgg16_Opset18_optimized.har?
Q3. How can I solve this? Or, first of all, is this conversion even possible?
TIA
(v3.30.0) koch@DESKTOP:/work$ hailo parser onnx --hw-arch hailo8l ../../vgg16_Opset18.onnx
[info] Current Time: 11:39:16, 08/13/25
[info] CPU: Architecture: x86_64, Model: 11th Gen Intel(R) Core(TM) i7-11700KF @ 3.60GHz, Number Of Cores: 16, Utilization: 0.0%
[info] Memory: Total: 31GB, Available: 30GB
[info] System info: OS: Linux, Kernel: 6.6.87.2-microsoft-standard-WSL2
[info] Running `hailo parser onnx --hw-arch hailo8l ../../vgg16_Opset18.onnx`
[info] Translation started on ONNX model vgg16_Opset18
[info] Restored ONNX model vgg16_Opset18 (completion time: 00:00:14.60)
[info] Extracted ONNXRuntime meta-data for Hailo model (completion time: 00:00:22.23)
[info] Start nodes mapped from original model: 'x': 'vgg16_Opset18/input_layer1'.
[info] End nodes mapped from original model: '/classifier/classifier.6/Gemm'.
[info] Translation completed on ONNX model vgg16_Opset18 (completion time: 00:00:24.67)
[info] Saved HAR to: /work/vgg16_Opset18.har
(v3.30.0) koch@DESKTOP:/work$ hailo optimize --hw-arch hailo8l --use-random-calib-set vgg16_Opset18.har
[info] Current Time: 11:42:06, 08/13/25
[info] CPU: Architecture: x86_64, Model: 11th Gen Intel(R) Core(TM) i7-11700KF @ 3.60GHz, Number Of Cores: 16, Utilization: 0.1%
[info] Running `hailo optimize --hw-arch hailo8l --use-random-calib-set vgg16_Opset18.har`
[info] Model Optimization Algorithm Mixed Precision is done (completion time is 00:00:00.11)
Calibration: 100%|███...███| 64/64 [00:32<00:00, 1.99entries/s]
[info] Model Optimization Algorithm Statistics Collector is done (completion time is 00:00:33.77)
[info] No shifts available for layer vgg16_Opset18/conv13/conv_op, using max shift instead. delta=0.5329
[info] No shifts available for layer vgg16_Opset18/conv13/conv_op, using max shift instead. delta=0.2664
[info] No shifts available for layer vgg16_Opset18/fc1/conv_op, using max shift instead. delta=1.4097
[info] No shifts available for layer vgg16_Opset18/fc1/conv_op, using max shift instead. delta=0.7049
[info] No shifts available for layer vgg16_Opset18/fc2/conv_op, using max shift instead. delta=1.4663
[info] No shifts available for layer vgg16_Opset18/fc2/conv_op, using max shift instead. delta=0.7331
[info] No shifts available for layer vgg16_Opset18/fc3/conv_op, using max shift instead. delta=1.3297
[info] No shifts available for layer vgg16_Opset18/fc3/conv_op, using max shift instead. delta=0.6649
[info] Adaround skipped
[info] The calibration set seems to not be normalized, because the values range is [(0.0, 1.0), (0.0, 1.0), (0.0, 1.0)].
Since the neural core works in 8-bit (between 0 to 255), a quantization will occur on the CPU of the runtime platform.
Add a normalization layer to the model to offload the normalization to the neural core.
Refer to the user guide Hailo Dataflow Compiler user guide / Model Optimization / Optimization Related Model Script Commands / model_modification_commands / normalization for details.
[info] Saved HAR to: /work/vgg16_Opset18_optimized.har
(v3.30.0) koch@DESKTOP:/work$ hailo compiler --hw-arch hailo8l vgg16_Opset18_optimized.har
[info] Current Time: 11:46:47, 08/13/25
[info] Running `hailo compiler --hw-arch hailo8l vgg16_Opset18_optimized.har`
[info] Compiling network
[info] Finding the best partition to contexts...
[...........................<==>.........] Elapsed: 00:42:51
[error] Mapping Failed (Timeout, allocation time: 1h 0m 19s)
Compiler could not find a valid partition to contexts. Most common error is: Automri finished with too many resources on context_3 with 119/1662 failures.
[error] BackendAllocatorException: Compilation failed: Compiler could not find a valid partition to contexts. Most common error is: Automri finished with too many resources on context_3 with 119/1662 failures.
