EULA question: can the AI SW Suite Docker image be stored in a private container registry or cloud machine image for internal compilation?
Hi all,
I have a licensing question about running the Hailo AI Software Suite in the cloud.
Versions:
  • Hailo AI Software Suite Docker image: 2024-10
  • Dataflow Compiler (DFC): 3.29.0
  • HailoRT: 4.19.0
Use case: I’d like to run the AI SW Suite Docker image on cloud GPU instances (AWS EC2) for internal model compilation only (ONNX → HAR → HEF). I’m considering two ways to get the image onto those instances:
  • (a) store it in a private container registry in my organization’s cloud account and pull it onto instances at run time, or
  • (b) save it inside a private machine image (AMI) in the same account.
In both cases the image would not be modified, redistributed, shared publicly, or made available to any third party.
The clause in question, Section 1.2 of the DFC EULA:
▎ “1.2. Restrictions. You agree that except as expressly permitted by Hailo in writing, you will not, nor allow any third party on Your behalf to … (b) modify, alter, copy, transfer, emulate or create any derivative works of the Licensed Software or of any part thereof;”
questions:
  1. Does either option, storing the image in a private container registry or in a private machine image, count as a “copy” under 1.2(b) that needs express written permission from Hailo?
  2. If it does, what’s the right channel to request that permission (support ticket or licensing contact)?
  3. Has anyone else run DFC compilation on cloud instances?
Thanks!
I’ll check with our team to see whether we can provide further clarification on the EULA.
In the meantime, I recommend discussing this with your company’s legal team. The terms and conditions of your cloud service provider may also be relevant, particularly regarding the use of third-party software on rented cloud infrastructure and the isolation of customer environments.
