Error during optimization (HAILO8)
Hi.
hailomz optimize --hw-arch hailo8 --har ./yolov11x.har yolov11x --calib-path ./train/images/
While I was running the command as above, I ran into the error message as below
What is this error and how can I solve this?
File “/home/sdkim/miniconda3/envs/hailo/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/script_parser/model_script_parser.py”, line 381, in parse_script
script_grammar.parseString(input_script, parseAll=True)
File “/home/sdkim/miniconda3/envs/hailo/lib/python3.10/site-packages/pyparsing/util.py”, line 436, in _inner
return fn(self, *args, **kwargs)
File “/home/sdkim/miniconda3/envs/hailo/lib/python3.10/site-packages/pyparsing/core.py”, line 1318, in parse_string
raise exc.with_traceback(None)
pyparsing.exceptions.ParseException: Expected end of text, found ‘change’ (at char 64), (line:2, col:1)
File “/home/sdkim/miniconda3/envs/hailo/bin/hailomz”, line 7, in
sys.exit(main())
File “/home/sdkim/miniconda3/envs/hailo/lib/python3.10/site-packages/hailo_model_zoo/main.py”, line 122, in main
run(args)
File “/home/sdkim/miniconda3/envs/hailo/lib/python3.10/site-packages/hailo_model_zoo/main.py”, line 111, in run
return handlersargs.command
File “/home/sdkim/miniconda3/envs/hailo/lib/python3.10/site-packages/hailo_model_zoo/main_driver.py”, line 225, in optimize
optimize_model(
File “/home/sdkim/miniconda3/envs/hailo/lib/python3.10/site-packages/hailo_model_zoo/core/main_utils.py”, line 351, in optimize_model
optimize_full_precision_model(runner, calib_feed_callback, logger, model_script, resize, input_conversion, classes)
File “/home/sdkim/miniconda3/envs/hailo/lib/python3.10/site-packages/hailo_model_zoo/core/main_utils.py”, line 315, in optimize_full_precision_model
runner.load_model_script(model_script)
File “/home/sdkim/miniconda3/envs/hailo/lib/python3.10/site-packages/hailo_sdk_common/states/states.py”, line 16, in wrapped_func
File “/home/sdkim/miniconda3/envs/hailo/lib/python3.10/site-packages/hailo_sdk_client/runner/client_runner.py”, line 502, in load_model_script
self._sdk_backend.load_model_script_from_file(model_script, append)
File “/home/sdkim/miniconda3/envs/hailo/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/sdk_backend.py”, line 492, in load_model_script_from_file
self._script_parser.parse_script_from_file(model_script_path, nms_config, append)
File “/home/sdkim/miniconda3/envs/hailo/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/script_parser/model_script_parser.py”, line 312, in parse_script_from_file
return self.parse_script(f.read(), append, nms_config_file)
File “/home/sdkim/miniconda3/envs/hailo/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/script_parser/model_script_parser.py”, line 389, in parse_script
raise BackendScriptParserException(f"Parsing failed at:\n{e.markInputline()}")
hailo_sdk_client.sdk_backend.sdk_backend_exceptions.BackendScriptParserException: Parsing failed at:
!<change_output_activation(conv120,sigmoid)
same error When retrain yolov5m compile model has error
