I downloaded the Hailo DFC software for the Hailo-8L (an 8.5GB file) after specifically selecting the Hailo-8L model on the webpage. However, during the final step—model optimization—the software reported that it was incompatible with the H8L, causing me to waste about three hours. The system indicated that I needed to install the hailo_ai_sw_suite_2025-10 version, yet this version is not available on your site. Why is this the case, and what is the reason for this?
Hailo-8/8L are now supported by the hailo8_ai_sw_suite_xxxx-xx versions, while hailo_ai_sw_suite_xxxx-xx supports Hailo-10 and Hailo-15.
For the individual packages, we continue to use the original version numbering (2.xx, 3.xx, and 4.xx) for Hailo-8, while the Hailo-10 package versions have been synchronized to version 5.x.
To access older versions, select Filter by: Archive
To find out what versions you need I recommend checking the Hailo AI Software Suite User Guide section: Release Versions Compatibility
how I can or where I can download hailo8_ai_sw_suite_xxxx-xx for 8l could you help
when I type this command system says not compatible for 8l
hailomz compile --ckpt yolov8n.onnx --hw-arch hailo8l --yaml yolov8n.yaml --classes 80 --calib-path /path/to/calibration/images
@Ekrem_Hacibektasoglu Please make sure that all SW packages you use are compatible with Hailo-8/Hailo-8L. The latest SW versions for these products are:
- HailoRT v4.24.0
- Dataflow Compiler v3.34.0
- Model Zoo v2.19.0
If you’re using the Model Zoo from GitHub, the relevant tag is at GitHub - hailo-ai/hailo_model_zoo at v2.19.0 · GitHub
If you prefer to download a Docker container with all these packages inside, it’s available from the Dev Zone too. It’s named hailo8_ai_sw_suite_2026-07_docker.zip.
If you prefer to work with the Hailo-8/8L SW version before the last one, it’s possible too. This version is still there in the archive (as Klaus mentioned). The relevant file name is hailo8_ai_sw_suite_2025-10_docker.zip.
problem solved only changed --hw-arch hailo8l in below command
hailomz compile yolov8m
--ckpt ./yolov8m.onnx
--calib-path /images/
--hw-arch hailo8l
so hailo8_ai_sw_suite_2026-07_docker is right software for 8L
