Damoyolo Compilation: Assertion `validate_context_placements(*result)' failed.
So, i finetuned a damoyolo network, followed every step of: hailo_model_zoo/training/damoyolo/README.rst at master · hailo-ai/hailo_model_zoo · GitHub
but:
I accidentally, successfully, compiled the onnx to a .hef for hailo10 instead of hailo8 so i know it can work (still no idea if the produced .hef does anything but that’s not the point here)
But when trying to convert the onnx to .hef for hailo8 (new venv, everything cleanly installed):
Assertion `validate_context_placements(*result)’ failed.
Full Flow
Start run for network damoyolo_tinynasL25_S …
[info] Translation started on ONNX model damoyolo_tinynasL25_S
[info] Restored ONNX model damoyolo_tinynasL25_S (completion time: 00:00:00.23)
[info] Extracted ONNXRuntime meta-data for Hailo model (completion time: 00:00:01.32)
[info] Start nodes mapped from original model: ‘images’: ‘damoyolo_tinynasL25_S/input_layer1’.
[info] End nodes mapped from original model: ‘Mul_239’, ‘Sigmoid_259’, ‘Mul_279’, ‘Sigmoid_299’, ‘Mul_319’, ‘Sigmoid_339’.
[info] Translation completed on ONNX model damoyolo_tinynasL25_S (completion time: 00:00:02.01)
[info] Saved HAR to: /media/mopf/data1/new_work/damoyolo_tinynasL25_S.har
Preparing calibration data…
[info] Loading model script commands to damoyolo_tinynasL25_S from /media/mopf/data1/new_work/hailo_model_zoo-2.16/hailo_model_zoo/cfg/alls/hailo8/base/damoyolo_tinynasL25_S.alls
[warning] Reducing compression ratio to 0 because the number of parameters in the network is not large enough (15M and need at least 20M). Can be enforced using model_optimization_config(compression_params, auto_4bit_weights_ratio=0.200)
[info] Model Optimization Algorithm Mixed Precision is done (completion time is 00:00:00.86)
Calibration: 100%|███████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████| 64/64 [00:31<00:00, 2.00entries/s]
[info] Model Optimization Algorithm Statistics Collector is done (completion time is 00:00:34.42)
[info] Output layer damoyolo_tinynasL25_S/conv60 with sigmoid activation was detected. Forcing its output range to be [0, 1] (original range was [7.490392454201356e-05, 0.8787712454795837]).
[info] Output layer damoyolo_tinynasL25_S/conv72 with sigmoid activation was detected. Forcing its output range to be [0, 1] (original range was [3.9649399695917964e-05, 0.9316549301147461]).
[info] Output layer damoyolo_tinynasL25_S/conv83 with sigmoid activation was detected. Forcing its output range to be [0, 1] (original range was [1.772598443494644e-05, 0.9362478852272034]).
[info] No shifts available for layer damoyolo_tinynasL25_S/conv82/conv_op, using max shift instead. delta=0.6360
[info] No shifts available for layer damoyolo_tinynasL25_S/conv83/conv_op, using max shift instead. delta=0.6301
[info] No shifts available for layer damoyolo_tinynasL25_S/conv83/conv_op, using max shift instead. delta=0.3150
[info] No shifts available for layer damoyolo_tinynasL25_S/conv82/conv_op, using max shift instead. delta=0.0030
[info] Adaround skipped
Full Quant Analysis: 100%|██████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████| 2/2 [02:22<00:00, 71.48s/iterations]
[info] Model Optimization Algorithm Layer Noise Analysis is done (completion time is 00:02:27.16)
[info] Output layers signal-to-noise ratio (SNR): measures the quantization noise (higher is better)
[info] damoyolo_tinynasL25_S/output_layer1 SNR: 21.4 dB
[info] damoyolo_tinynasL25_S/output_layer2 SNR: 7.215 dB
[info] damoyolo_tinynasL25_S/output_layer3 SNR: 23.24 dB
[info] damoyolo_tinynasL25_S/output_layer4 SNR: 10.28 dB
[info] damoyolo_tinynasL25_S/output_layer5 SNR: 27.56 dB
[info] damoyolo_tinynasL25_S/output_layer6 SNR: 17.93 dB
[info] Building optimization options for network layers…
[info] Successfully built optimization options - 5s 457ms
[info] Running Auto-Merger
[info] Auto-Merger is done
compiler: ../src/allocator/context_split.cpp:75: static std::shared_ptrallocator::ContextSplit allocator::ContextSplit::Create(std::shared_ptr<utils::GraphInterface<network_graph::NetworkNode, network_graph::NetworkEdge> >, const NodesByContextMap&, const allocator::ContextPlacements&): Assertion `validate_context_placements(*result)’ failed.
I’m so close to being done with this shit, even the predefined tutorial stuff doesn’t work…
Please has anyone an idea?!
Hi @Gama_Holic
If you can share the onnx file, we can see if we can compile it for you.
Hey @Gama_Holic,
Your model makes it all the way through quantization and only fails during the final allocation step on Hailo-8, which means this is almost certainly a resource placement issue rather than a fundamental problem with your model.
Here’s what’s happening and how to fix it:
The Main Issue: Your ONNX export still has sigmoid activations inside the graph. I can see from your log that the system detected sigmoid outputs and forced the range to [0,1]. For YOLO-style detection heads, we want raw logits as outputs and handle the sigmoid activation in post-processing. Keeping activations in-graph creates memory pressure that prevents clean context splitting on Hailo-8.
Quick Fix Steps:
  1. Re-export your ONNX properly: Make sure your three detection heads end at the raw convolution outputs (no Sigmoid, no Mul operations for obj*cls). Point your end nodes to these conv logits exactly like the damoyolo_tinynasL25_S recipe expects.
  2. Add the performance optimization: Include performance_param(compiler_optimization_level=max) in your model script. This gives the allocator more flexibility for fusion and tiling.
  3. Regenerate everything: Since your current calibration was done with sigmoid in-graph, you’ll need to regenerate the HAR with the clean logits-only export, then recalibrate and recompile.
If you can share your current end-node names and model script snippet, I can help pinpoint exactly what needs changing. This type of assertion failure is usually resolved by moving the activations to post-processing - once that’s done, H8 typically compiles without issues.
Let me know how it goes!
Hi there,
I’m actually having the same problems with the Small model. I can compile the tiny and medium models without issue in the Docker Suite. Does anything odd stand out about the heads of this graph?
matrix_damoyolo_tinynasL25_S.onnx
