damo-yolo models
Hi all,
I have HAOS on a rpi5 with hailo-8L. I am using frigate and I tried both yolov11n (15 ms inference time) and yolov11s (29 ms). I also downloaded damo-yolo L25 from model zoo but I get 0 detections, does it mean it is not supported from frigate or is there anything wrong with my configuration? Relevant part of my config file is attached,
thank you in advance
Cristiano
model:
width: 640
height: 640
input_tensor: nhwc
input_pixel_format: rgb
input_dtype: int
model_type: yolo-generic
labelmap_path: /labelmap/coco-80.txt
# The detector automatically selects the default model based on your hardware:
# - For Hailo-8 hardware: YOLOv6n (default: yolov6n.hef)
# - For Hailo-8L hardware: YOLOv6n (default: yolov6n.hef)
# Optionally, you can specify a local model path to override the default.
# If a local path is provided and the file exists, it will be used instead of downloading.
# Example:
#path: /config/model_cache/yolov6n-640.hef
#path: /config/model_cache/yolov11s.hef
path: /config/model_cache/damoyolo_tinynasL25_S.hef
The yaml config for custom model should look like:
model:
  width: 640
  height: 640
  input_tensor: nhwc
  input_dtype: int
  path:
    https://some-path-to.hef
Can you please confirm this is the configuration you’re using?
thank you for the reply, yes this is the config I am using:
model:
width: 640
height: 640
input_tensor: nhwc
input_dtype: int
path: …
best C.
Hi @Cristiano_De_Michele,
Can you please provide the URL of the model you downloaded?
Hi Michael,
the model is the following one:
https://hailo-model-zoo.s3.eu-west-2.amazonaws.com/ModelZoo/Compiled/v2.18.0/hailo8l/damoyolo_tinynasL25_S.hef
best C.
Cristiano De Michele
cristiano.demichele@gmail.com
I suspect the issue is that “DAMO YOLO” not falls under the “yolo-generic” type and therefore the post process is different.
Dear Michael,
it was also my guess,
hence there is no anything I can
do to fix it, since it should be
done by frigate developers, right?
best Cristiano
Maybe a clue for your issue. I also run frigate on a pi5 and hailo8 hat. I had a similar issue but with the yolov11s.
The link you provided showed that is has been compiled with a v2.18 , which corresponds to 4.23 hailo driver.
Frigate is only compatible (for now) with 4.21 driver version , so you need v.2.15 compiled version.
Just change “18” by “15” in the download link and you’ll get the correct file, and give it a try.
https://hailo-model-zoo.s3.eu-west-2.amazonaws.com/ModelZoo/Compiled/v2.15.0/hailo8l/damoyolo_tinynasL25_S.hef
