Hi everyone,
I am trying to compile a custom DeepLabV3 + MobileNetV3-Large lane-segmentation model for Hailo-8 with DFC 3.33.1.
Current setup:
- ONNX opset 11
- static input: 1x3x384x384
- 6 classes
- custom exported ONNX from PyTorch
- global avgpool ops already patched out
- auxiliary head removed
- conservative model script (optimization_level=0, compression_level=0, batch_size=1, calibset_size=64)
What happens:
hailo parser onnxsucceedshailo optimizesucceeds- partitioning succeeds
- final compile fails during mapping with:
BackendAllocatorException: Compilation failed: Value doesn't fit in field (1411)
The hailo_sdk.core.log also shows multiple microcode violations around resize* / conv* layers before the failure.
I already tried reducing input size:
- 512 → fail
- 448 → fail
- 384 → still fail
Question:
Is DeepLabV3 + MobileNetV3-Large / resize-heavy ASPP segmentation known to hit a compiler/backend limitation on Hailo-8?
Thanks.
