Hello Hailo team,
We are designing a custom carrier board for a Raspberry Pi Compute Module 5 with a Hailo-8 industrial device (HNC18BI11BH) soldered directly on the PCB (chip-down), connected over PCIe Gen 2 x1 (lane 0 only). We source the devices from Farnell (order code 4906514).
We have the Hailo-8 datasheet Rev 1.9.2 (April 2026). It refers to the Hailo-8 Board Design Guidelines / Hardware Integration Guide, which we could not find publicly. Could you share this document and, if possible, the PCIe reference design (schematic + BOM), under NDA if required?
In particular, we need the following information:
- PCIE_CMN_REXT (ball D11): required resistor value, tolerance and connection (to GND?).
- Unused PCIe lanes 1–3 (TX/RX): leave floating, or terminate/ground?
- Power rail decoupling: recommended capacitors for VDD, VDDIO, PCIE_AVDD_C, PCIE_AVDD_D, PCIE_AVDD_H, PLL_VDDA, AVDD_TS/VS, and recommended filtering (ferrite beads) for the analog rails. Can PCIE_AVDD_C/D and PLL_VDDA be derived from the VDD regulator through ferrite beads?
- VDD regulator sizing: is a 12 A regulator appropriate, or what peak current should we design for at 26 TOPS?
- Power sequencing: we enable VDDIO first, then VDD from VDDIO power-good, and we actively discharge VDD on power-down. Is this acceptable? Is any constraint violated if the supply is lost abruptly?
- Reset: is it acceptable to drive NRESET and PCIE_PERST_N together from the host PERST# (AND-ed with VDD power-good, 1.8 V push-pull)?
- Ball U5: the ball map shows GND, but the pin table does not list it, and an earlier revision says “U5 removed from GND”. Should it be connected to GND or left unconnected?
- PCB land pattern: recommended pad diameter (SMD/NSMD), solder mask opening, and fan-out guidelines. Can the design be done on a 4-layer PCB without via-in-pad?
- Thermal: recommended heatsink/thermal solution for passive cooling at ~2.5 W typical.
- Assembly: MSL level and baking requirements.
We would also appreciate a schematic/PCB design review once our design is ready.
Thank you very much for your help.
Best regards,
Leo
